Charbel101
Aug 05, 2019Follower
Cannot reset password on Orbi app
I have been trying to access the app and it is not allowing me to reset password when I click forget password an error 404 comes up. I also can’t remember what my security questions were. Can someone ...
CrimpOn
Aug 06, 2019Guru - Experienced User
You might try posting in the Orbi "app" forum.https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Mine connects automatically, and I have yet to find any way to change the admin password using the app.
I notice on the first page (that goes away in a few seconds), it says "Having problems connecting? Try a new setup"
Silly me, I assume this means to get out the paperclip and do a "factory reset".
Good Luck
