Fossil1
Apr 07, 2019Aspirant
Cannot send email using WIFI
I cannot send email when using our ORBI 53 WIFI router. Used my iPhone as a hotspot and it worked fine. Also works when I'm on a different WIFI. It had been sending and receiving just fine until a...
Apr 07, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Fossil1 wrote:
I cannot send email when using our ORBI 53 WIFI router. Used my iPhone as a hotspot and it worked fine. Also works when I'm on a different WIFI. It had been sending and receiving just fine until a few day ago. Had the same problem with a proir Netgear WIFI model.
Fossil1
Apr 09, 2019Aspirant
I have update the firmware to the most current version. The wifi router is connected to the ISP modem which is and SMC that was provided by the ISP provider, Mediacom.
