Jsl05
Mar 25, 2020Tutor
Cannot send images over wifi
I cannot send images via imessage or upload to the cloud on my wifi all of a sudden. any help?
Jsl05
Mar 28, 2020Tutor
Well...i guess that is good to hear! I spent 2 hours on with Netgear support and they could not figure it out. I am also having the same slowness uploading to amazon photo so you can add that one to your list as well. However I tried uploading from my computer on wifi to amazon and it worked ok. If I get anywhere tomorrow with netgear I will let you know as well. How
Mar 29, 2020Guru - Experienced User
What did netgear have you try doing?
Did you try changing dns providers? you could try google's at 8.8.8.8 or 8.8.4.4 or cloudfare at 1.1.1.1
try enabling/disabling ipv6?
