Jsl05
Mar 25, 2020Tutor
Cannot send images over wifi
I cannot send images via imessage or upload to the cloud on my wifi all of a sudden. any help?
Dfortune
Apr 05, 2020Aspirant
I am having the exact same problem with optimum. Not just iMessage but also Dropbox and OneDrive. But google drive upload speed is 40mbs.
I did not have this problem before. I even upgraded thinking I was overwhelming the system with everyone home. Download is 400. Upload is 40 on Speedtest, but if I put a file in Dropbox and watch it syncs it does not break 24kbs. Then same file to Googledrive it is 40mbs.
using Eero. Plugged computer directly into router to test DropBox and OneDrive and same problem, which takes eero out.
Turned on Encrypt.me which is a VPN. No problem sending the same image via text.
This is definitely some kind of throttle.
