Robertgold123
Apr 19, 2020Tutor
Cannot Set Up RBS50Y in Extender Mode
I have been using the RBS50Y for the past year without a problem until I upgraded my router and satellites to the RBK852 AX 6000 system. I know the RBS50Y will not work with the AX system in Orbi mo...
CrimpOn
Aug 26, 2020Guru - Experienced User
(Snark) Kind of typical of Netgear to omit the relevant information, such as "Devices manufactured prior to xx/xx/xx cannot be put into Extender Mode" or "Devices with serial numbers lower than xxxxx cannot be put into Extender Mode."
In other words: How do I know if MY RBS50Y can be put into Extender Mode? Good Luck.
TheRandy
Aug 26, 2020Aspirant
That's exactly what I'm thinking right now!
I'm going to call them and see if they will replace it with the "V2" version. Doubtful, but worth a shot.
