Robertgold123
Apr 19, 2020Tutor
Cannot Set Up RBS50Y in Extender Mode
I have been using the RBS50Y for the past year without a problem until I upgraded my router and satellites to the RBK852 AX 6000 system. I know the RBS50Y will not work with the AX system in Orbi mo...
CrimpOn
Aug 26, 2020Guru - Experienced User
Mstrbig wrote:
https://kb.netgear.com/000060131/How-do-I-set-up-my-Orbi-Outdoor-Satellite-in-Extender-Mod
I guess this is what TC_in_Montana was saying. The way to know if a specific RBS50Y is able to go into extender mode is to follow the directions, over and over, and finally give up because they never work.
Mstrbig
Aug 26, 2020Master
CrimpOn wrote:
Mstrbig wrote:
https://kb.netgear.com/000060131/How-do-I-set-up-my-Orbi-Outdoor-Satellite-in-Extender-ModI guess this is what TC_in_Montana was saying. The way to know if a specific RBS50Y is able to go into extender mode is to follow the directions, over and over, and finally give up because they never work.
Agreed, but he also said he could not find the Extender firmware. In order to be able to put the RBS50Y into Extender mode, the firmware has to be present.
- TC_in_MontanaAug 26, 2020Virtuoso
Mstrbig wrote:
Actually, what I said was I looked for the special updates that were needed to convert the V1 to V2 that were used during the beta test.
I know where the firmware updates are for the RBS50Y. Believe me, I have loaded EVERY SINGLE firmware update for the RBS50Y since receiving it. Even some that no longer exist on the "Prior Versions" page.
Unfortunately, you can not load the Extender Mode firmware unless you are in Extender Mode. If you are in Orbi Satellite Mode, it will not allow you to load it. And loading the Orbi Satellite firmware, does not enable the Extender Mode. That is the quandry.
