zenobios
Feb 05, 2021Tutor
Cannot synchronize RBS20 to RBR40
Hi guys, I have a RBR40 router and two RBS40 satellites wich I bought as package ~2 years ago. Now I wanted to add a new satellite and saw that - at least on Amazon - you can't buy the RBS40 anym...
- Feb 08, 2021
I solved the problem by switching off all satellites and just keep the router turned on. I guess it's a problem when there too many satellites nearby during the synchronization process. The system works fine now.
vajim
Feb 05, 2021Master
The RBS20 satellite is compatible with the RBK20W, RBK22, RBK23, RBK23W, RBK30, RBK33, RBK40, RBK43, RBK43S, RBK44, RBK50, RBK50V, RBK52W, RBK53, RBK53S systems.
https://www.downloads.netgear.com/files/GDC/RBS20/RBS20_QSG_EN.pdf
