zenobios
Feb 05, 2021Tutor
Cannot synchronize RBS20 to RBR40
Hi guys, I have a RBR40 router and two RBS40 satellites wich I bought as package ~2 years ago. Now I wanted to add a new satellite and saw that - at least on Amazon - you can't buy the RBS40 anym...
- Feb 08, 2021
I solved the problem by switching off all satellites and just keep the router turned on. I guess it's a problem when there too many satellites nearby during the synchronization process. The system works fine now.
vajim
Feb 05, 2021Master
The RBS20 satellite is compatible with the RBK20W, RBK22, RBK23, RBK23W, RBK30, RBK33, RBK40, RBK43, RBK43S, RBK44, RBK50, RBK50V, RBK52W, RBK53, RBK53S systems.
https://www.downloads.netgear.com/files/GDC/RBS20/RBS20_QSG_EN.pdf
zenobios
Feb 05, 2021Tutor
So then I'm wondering where the problem is...
- vajimFeb 05, 2021Master
zenobios wrote:So then I'm wondering where the problem is...
we're waiting for you to try it and let us know
thanks
- zenobiosFeb 05, 2021Tutor
thanks
Oh well - is there some kind of sarcasm in it or did I miss something :smileyvery-happy:
thanks
no you're fine:smileyhappy:....i thought you had the info you needed and of course if all else fails, reboot and perform a factory reset.
