zenobios
Feb 05, 2021Tutor
Cannot synchronize RBS20 to RBR40
Hi guys, I have a RBR40 router and two RBS40 satellites wich I bought as package ~2 years ago. Now I wanted to add a new satellite and saw that - at least on Amazon - you can't buy the RBS40 anym...
- Feb 08, 2021
I solved the problem by switching off all satellites and just keep the router turned on. I guess it's a problem when there too many satellites nearby during the synchronization process. The system works fine now.
vajim
Feb 05, 2021Master
zenobios wrote:
vajim wrote:
zenobios wrote:So then I'm wondering where the problem is...
we're waiting for you to try it and let us know
thanks
Oh well - is there some kind of sarcasm in it or did I miss something :smileyvery-happy:
no you're fine:smileyhappy:....i thought you had the info you needed and of course if all else fails, reboot and perform a factory reset.
zenobios
Feb 08, 2021Tutor
