Kensington6503
Jul 03, 2021Aspirant
Cannot tell if Satellites are working!
This is a post about the RBK853|Orbi Tri-band Mesh WiFi6 System (not apparently a selection option yet). I don't think it really matters, though, for my question/problem. I set up the RBR in AP m...
Jul 03, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Kensington6503
Thank you! I did not know, obviously.
- FURRYe38Jul 03, 2021Guru - Experienced User
You've been updated now.
Good Luck.
