trabba
Jul 25, 2022Tutor
Cannot Unblock Occulus Quest
I successfully connected the Occulus Quest 2 to the Orbi RBR50. It worked well for a couple of weeks. When I used the "block internet access" function via the app it would not recconnect. I have g...
CrimpOn
Jul 25, 2022Guru - Experienced User
Sometimes I forget to follow through all the steps:
- Check the box next to the device that is blocked.
- Click the "Allow" Button.
- Click the "Apply" Button.
I understand that people are drawn to this Access Control feature, but (personally) I find that it seems to cause more problems than it is worth. If someone can guess my 20 character WiFi password, they are welcome to steal my WiFi, provided that they can get close enough to my house to get a good signal. I leave it turned off.
- trabbaJul 25, 2022TutorThanks Crimp on. Yep have followed this steps. Also went into the edit function to try an alternate way. This does not work either.
- CrimpOnJul 25, 2022Guru - Experienced User
trabba wrote:
Thanks Crimp on. Yep have followed this steps. Also went into the edit function to try an alternate way. This does not work either.Have you tried disabling Access Control completely?
- trabbaJul 26, 2022Tutor
Sure Have...access control is turned off and still the device is blocked
