jamieh922
Jan 26, 2021Aspirant
Cannot update firmware on Orbi App, Satelittes not found on Orbi App
Hello, My I have the RBR50 with 2 satellites. I have 2 major problems. 1) My firware version is V2.5.1.6 and I know there is a version 2.7.1.60. The Orbi App says "update" and I go through the wh...
Rawcus
Jan 27, 2021Tutor
I recommend you not upgrading via the website and doing it manually and waiting for the automatic process to work.
- vajimJan 27, 2021Master
Rawcus wrote:
I recommend you not upgrading via the website and doing it manually and waiting for the automatic process to work.Nice
I recommend you upgrade via the website and do NOT do it manually or wait for the automatic process to work.
then enjoy your orbi
if it works leave it alone
- RawcusJan 27, 2021TutorObviously writing on a phone isn’t the best. However the automatic process should work and everyone just recommending to do it manually should stop saying that.
And that meant to say
I recommend you upgrade it with the app automatically and contact Netgear until it works. Do not upgrade it via the manual process that involves there website.
Just want to add a second time stop advising people to do it manually like it’s some beta software that can’t handle the “automatic” process.
- RawcusJan 27, 2021TutorI recommend you not upgrading via the website or doing it manually and waiting for the automatic process to work.
:smileymad:
