jamieh922
Jan 26, 2021Aspirant
Cannot update firmware on Orbi App, Satelittes not found on Orbi App
Hello, My I have the RBR50 with 2 satellites. I have 2 major problems. 1) My firware version is V2.5.1.6 and I know there is a version 2.7.1.60. The Orbi App says "update" and I go through the wh...
vajim
Jan 27, 2021Master
Rawcus wrote:
I recommend you not upgrading via the website and doing it manually and waiting for the automatic process to work.
Nice
I recommend you upgrade via the website and do NOT do it manually or wait for the automatic process to work.
then enjoy your orbi
if it works leave it alone
Rawcus
Jan 27, 2021Tutor
Obviously writing on a phone isn’t the best. However the automatic process should work and everyone just recommending to do it manually should stop saying that.
And that meant to say
I recommend you upgrade it with the app automatically and contact Netgear until it works. Do not upgrade it via the manual process that involves there website.
Just want to add a second time stop advising people to do it manually like it’s some beta software that can’t handle the “automatic” process.
