NikolajLunoe
Apr 04, 2019Aspirant
Cannot update NetGear Orbi RBR50 Router firmware
I have a NetGear Orbi RBR50 Router + an Orbi RBS50 Satellite (both bought in January 2017). My computer is running version 2.2.1.210 of the firmware for the set (router + satellite) in a Mozilla Fire...
- Apr 04, 2019
Download the v44 files for both RBR and RBS. Download the RBR v212 only.
You can directly update the RBS to v44 from v210. I just did this last night on mine.
You do have to update to v212 first on the RBR, then you can apply v44 on the RBR lastly.
I would use IE11 or Firefox browser. After downloading the .zip files and unpacking them, do not attemp to open the .IMG file. It's not damaged. It's just not readable by your PC. Just leave it alone.
Log into the RBRs web page with IE11 or FF browser and go to the firmare update section. Select manual update and navigate to the RBS file. Do this first. You can even log into the RBS web page and update it from there which is preferred. After the v44 has been loaded on the RBS, load the v212 on to the RBR using the RBRs FW update web page. After v212 is loaded on the RBR, do the same thing again for v44. After all has been loaded, use the Backup web page on the RBR to factory reset "ERASE" the system back to default settings. Walk thru the setup wizards and setup the system from scratch. Be sure to do a Backup of the configuration to file for safe keeping later on.
NikolajLunoe wrote:
I have a NetGear Orbi RBR50 Router + an Orbi RBS50 Satellite (both bought in January 2017). My computer is running version 2.2.1.210 of the firmware for the set (router + satellite) in a Mozilla Firefox Quantum version 66.0.2 (64-bit) browser on a Windows 10 computer.
I would like to perform an update of the firmware – and understand that I must install version 2.2.1.212, before I can install version 2.3.1.44 which is the latest “edition” (as of today, April 4th, 2019). However, I can do neither. Here’s why:
(1) Firstly, when I open the http://www.routerlogin.net/index.htm and click the “Advanced\Administration\Firmware update” tab, the message “Please wait a moment” appears (in Danish, atop a blank page) ― and then, nothing happens. I have repeated this process many times, and waited for hours for the “Update” page to appear, but always remain stuck with the “Please wait” message.
(2) Secondly, if I try downloading the .zip-file supposed to contain version 2.2.1.212 of the firmware via this site
https://www.netgear.com/support/download/
and then unpack it, it produces two files – named “RBR50-V2.2.1.212.img” and “RBR50_RBS50-V2.2.1.212_Release_Notes.html”. But when I try to double-click the .img-file I see an error message from Windows informing me that this file has been damaged.
What should I do? I would be most grateful for any advice.
Kind regards, Nikolaj Lunoe, Copenhagen, Denmark.
Apr 04, 2019Guru - Experienced User
