taperanger
Jul 03, 2019Initiate
Cannot Update Orbi RBW30 Firmware to 2.3.5.6
Looking to update the firware for my satelites (both RBW30) from 2.3.0.4 to the lastest version - 2.3.5.6. The web interface shows "downloading firmware" for both using the auto-check but then sudden...
CrimpOn
Jul 04, 2019Guru - Experienced User
taperanger wrote:The other manual update options for each individual satelite require passwords since they are on different internal IP's. I have no idea what these are since I never set them.
The Orbi router Attached Devices page should show the satellites at the top, including the IP address of each satellite. Use a web browser and go to http://(that IP). The credentials should be "admin" and the same password as the Orbi router.
michaelkenward
"Should be" may underestimate things.
I just went and looked. I can see no way of changing the management password.
But we need feedback from taperanger before we can say much more.
