cmihaly's avatar
cmihaly
Tutor
Jul 06, 2020
Cannot update RBR50 Router, but could updatd RBS satellite
I bought a new RBK50 router.  I instaled int, having troubles with internet connectivity.  The Advanced Firmware Auto says it is up to date with 1.4.18 but the Netgear Support site says there is a 2....
  • CrimpOn's avatar
    CrimpOn
    Jul 06, 2020
    Your version is SO OLD that it might need to update to something before "212" in order to be able to get to 212.
    FURRYe38has identified an intermediate step before.  Maybe he will remember what you need to do.
