naumanC
Jun 16, 2019Follower
Cannot update RBS50 from 2.2.1.210 - firware file is incorrect
I cannot update the satelite RBS50 from 2.2.1.210. I have tried downgrading manually as well as updating to 2.2.1.212 but I keep getting the message that the firmware file is incorrect. MY RBR50 upda...
CrimpOn
Jun 16, 2019Guru - Experienced User
Can you connect the PC directly to the RBS50 web interface? Click on the firmware update on the Sattelite home page. Browse to the firmware file, which should be "RBS50-V2.3.1.60.img" (after extracting from the zip archinve).
The Download page cautions about upgrading from "210", but that caution refers to the router, not the satellite.
