PurplePJ
Aug 19, 2020Guide
Cannot Verify Server Identity
I installed an Orbi and one satellite. During installation, and since then, I keep getting this error message on my iPhone: Cannot Verify Server Identity, The Identity of “m.hotmail.com” cannot be v...
Mstrbig
Sep 23, 2020Master
PurplePJ wrote:I installed an Orbi and one satellite. During installation, and since then, I keep getting this error message on my iPhone: Cannot Verify Server Identity, The Identity of “m.hotmail.com” cannot be verified. Button choices are "Details" and "Cancel" neither of which do anything other than make the notification go away only to return again later.
I don't have a hotmail account. Any ideas?
Pete.
Upon furter searching it has nothing to do with OPrbi and is an IOS update error, happening on many I devices.
If you are going to orbilogin.com, since there is no certificate, it may be generating it there, but it shouldn't anywhere else.
When your iPhone prompts you with, “cannot verify server identity” error, it's telling you that the mail server's certificate is fake. In short, this error occurs due to your iPhone's strict verification of your mail server certificates.
First solution: Quit and restart the Mail app.
Second solution: Soft reset/reboot the iPhone
Third solution: Remove your email account then add it back
Fourth solution: Update iOS and carrier settings
Fifth solution: Reset network settings
Last resort: Factory reset/master reset
Also, remove any microsoft product apps like word, etc and reload.
