09TheMobLordXx
Jan 16, 2022Aspirant
Can't access 192.168.1.1
So a few months ago I used to be able to go to http://192.168.1.1 and port forward and manage some stuff. Recently it just "This site cannot be reached" and I can't access the website, I have checked...
CrimpOn
Jan 16, 2022Guru - Experienced User
Thanks for including the image. What browser is this? Does the "Details" box bring up anything useful?
I would open a DOS Window (or the equivalent in Linux and Mac) and try to 'ping' the Orbi.
The gateway is showing as 192.168.1.1, correct?
09TheMobLordXx
So I am currently using Chrome as my browser. Also when I open details it just shows some useless suggestions i've already tried like "check your internet connection" and stuff. Also I don't know what a DOS window is but I can ping it by going into my cmd and doing the cmd 'ping 192.168.1.1'. So I just did it and this is what it gave me.
- CrimpOnJan 16, 2022Guru - Experienced User
Thanks. Really old people remember this as a "DOS Window". So the Orbi router is definitely present and alive.
Can you try a different browser?
How about trying the secure web portal: https://192.168.1.1
The browser will complain about it being "insecure" because the SSL certificate is "self-signed". Just ignore the warning.
You are probably aware that the "last resort" is to do a Factory Reset and reconfigure the router from scratch. (I absolutely hate doing this. It takes me over two hours to make all the configuration settings on my router.)
- 09TheMobLordXxJan 16, 2022Aspirant
So I did everything you said and unfortunatly it doesn't work, I guess we'll have to factory reset it. I'll wait for more answers tho before I do so if anybody else can help me that'd be nice
- Mikey94025Jan 16, 2022Hero
09TheMobLordXx wrote:So I did everything you said and unfortunatly it doesn't work, I guess we'll have to factory reset it. I'll wait for more answers tho before I do so if anybody else can help me that'd be nice
And after restarting the Orbi, you still can't get to http://192.168.1.1? You've said you already tried different devices but to be complete and to ensure your browser is just not prompting you for the admin/password, try using a different browser and go to http://192.168.1.1.
