LuizAlmeida's avatar
Nov 11, 2020
CAN'T ACCESS A NETWORK RESOURCE IN ANOTHER RBS50 SATELLITE
Hi,   I have a RBR50 set and I have internet in all its the satellites. Through the orbilogin.net I can see the satellites with GOOD in the Backhaul Status as you can see below:     The O...
  • FURRYe38's avatar
    Glad its working now. Enjoy, :smileywink:
    LuizAlmeida wrote:
    Hi,
    I waited for the weekend and did a factory reset in all my Orbis (RBR50, RBS50 and RBS50Y).
    Everything now is showing online (Orbi App and Orbi's web administration console).
    I can even check for new firmware update through the Orbi's web administration console.
    The only thing is my RBS50Y shows firmware update failed after check is done (but there is no firmware update to do at the time as it is running the 2.6.1.40 version).
    I had to configure all my network configuration by hand as someone else in the community claimed the factory reset procedure kept the old problems when using the backup file.
    I hope not to do the same again.
    Thank you for the tips.
    Best Regards,
    Luiz Almeida
