rhg76
Aug 04, 2019Tutor
Can't access certain websites or update Apps through Orbi
Hi folks I'm currently unable to access certain websites or update Apps on my iphone. One of the websites I can't access is orbilogin.com I'm not hugely technically minded but will do my best to provi...
Talk2Mike
Aug 04, 2019Apprentice
You need to set the Orbi up as an access point and not a router, otherwise you will be suffering double NAT. I don't think you can set the BT Homehub into a modem mode so the only other way would be to make the Orbi IP a DMZ in the BT router.
- rhg76Aug 04, 2019TutorThanks very much Mike
In order to set the Orbi router in AP mode I believe I need to be able to access the router settings. However orbilogin.com is one of the sites I can’t access.
Any ideas how I can access this site or make this change in a different way?- ekhalilAug 05, 2019MasterCan you access the web GUI using IP address, that is 192.168.1.1?
If you can’t then please disconnect Orbi from the ISP router, and reboot Orbi, and see if you’ll be able to access the web GUI then.
