rodstar1
Sep 18, 2019Aspirant
Can't access Orbi interface at times, after reset, reboot it works then the problem returns.
I hope someone knows the solution. I can't access my Orbi at random times and have to restart the Orbi and I have reset the Orbi, it fixes the issue for a little while and the problem returns? I have...
Sep 18, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
What browsers are you using?
Wired or wireless when your trying to access the CBRs web page?
Using 192.168.1.1 or orbilogin.com?
rodstar1 wrote:I hope someone knows the solution. I can't access my Orbi at random times and have to restart the Orbi and I have reset the Orbi, it fixes the issue for a little while and the problem returns? I have tried multiple browsers and computers and have updated the firmware.
- rodstar1Sep 18, 2019Aspirant
I have completed a factory reset twice, it is wirelessly and remotely problematic. This issue is on chrome, safari, opera and Firefox using MacBook Pro and IPad Pro.
- FURRYe38Sep 19, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite.
