rodstar1
Sep 18, 2019Aspirant
Can't access Orbi interface at times, after reset, reboot it works then the problem returns.
I hope someone knows the solution. I can't access my Orbi at random times and have to restart the Orbi and I have reset the Orbi, it fixes the issue for a little while and the problem returns? I have...
rodstar1
I have completed a factory reset twice, it is wirelessly and remotely problematic. This issue is on chrome, safari, opera and Firefox using MacBook Pro and IPad Pro.
Sep 19, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite.
