Kaps77's avatar
Kaps77
Follower
May 31, 2019
Can't Access OrbiLogin.net, don’t want to reset system
I can’t access OrbiLogin.net, wrong password. Then when I try use S/N Security Questions, they just kick me back to the Security Questions. I am very apprehensive about resetting my Orbi because then I have to use a new WiFi access password and update every device attached to WiFi. Help!
1 Reply
  • Unfortunately, your only option is to factory reset Orbi.
    If you use the same Wifi SSID and password as you currently have, you will not need to redo the wifi attach of the devices that are currently attached to Orbi.
