mastervisa30
Nov 02, 2018Luminary
cant access remote management?
On my old broken orbi i had its was working.
But now i cant get it to work on my new orbi?
i cant enable remote management in my appjust get some error occured . maybe ist becouse my old orbi is ...
Nov 02, 2018Guru - Experienced User
What FW is currently loaded?
Try enabling the remote management with a PC connected to the orbi router and navigating to this feature on it's web page first...
mastervisa30
Nov 05, 2018Luminary
im using latest firmware,i have rbk53 one router and two satelites,its working on the web browser if im not home,but its not working on my app on iphone x.
i have sent this to netgear support but not getting any help.
RBR50 - i cant enable remote management in my appjust get some error occured . maybe ist becouse my old orb please delet my old defekt orbi serial 4RTC815500xxx THIS SERIAL I DONT HAVE ANYMORE please delet from my acounttest@hotmail.com,my new and only orbi system is xxxxxxxxxxxx please delet my old if that is the problem that i cant enable remote control management in the orbi app.
Yes its activated one settings menu and enable all acsess ,but it doesnt work on the app cant activate remote managemen
- FURRYe38Nov 05, 2018Guru - Experienced User
- mastervisa30Nov 05, 2018Luminary
I have enabling the remote management with a PC connected to the orbi router and navigating to this feature on it's web page first.
Its working from my phone if ui use the web browser,but its not working on the app enable managenent setting on.its have worikng before on my old orbi system,its was broken and i got new orbi same system now latest firmware Firmware Version 2.2.1.210
Try removing the app from the mobile device. Reboot the device, then re-install the app.
