Francois2
Nov 01, 2019Follower
Can't access to NAS
Hi, I have a NAS wired on Router (DHCP server 192.168.1.1). My RBR20 is wired on router as a Bridge (10.0.0.1) When on LAN I can see my NAS but by WIFI I Can't Where I should setup my problem.....
Nov 01, 2019Guru - Experienced User
Try putting the RBR in AP mode or connect the NAS to the RBR.
Having two routers on the same line will cause problems.
Francois2 wrote:Hi,
Where I should setup my problem.......RBR20 or Router to see my NAS?
Thanks
