bayoyong
Mar 11, 2018Tutor
Can't Add Circle
Model is RBR20. Wasn't listed in list. Trying to add Circle. Says it's built in. Says it's compatible. When I try to pair from the Circle app, it says I need to update the firmware. Click update....
BigD56
Mar 12, 2018Aspirant
Can you verify your model and firmware version? Best to login to the router through your browser and go to Advanced Tab to check router information.
- bayoyongMar 12, 2018Tutor
Hardware Version RBR20 Firmware Version V2.0.0.64 GUI Language Version V1.0.0.302 Operation Mode Router - StarbuckyMar 12, 2018Apprentice
Circle is not included with firmware 2.0.x only the 2.1.x have Circle integration.
- BigD56Mar 12, 2018Aspirant
You need to upgrade to the latest firmware version. Unforunatly the utility in the web administration does not show available updates and may even list your version as current. You will need to go directly to Netgear support page and find the update. When you are on the page that shows your firmware version look for the "Previous Versions" link. Under that you will find the current 2.1.1.X version for your RBR20. You will need to do a manual update from the Advanced->Administration tab. If you have any satillites make sure to do the master router first.
Current available version for your RBR20 is 2.1.2.18.
