RocketSquirrel's avatar
Feb 20, 2023
Can't allow Guests to access network
There are times I would like to temporarily allow a guest access to my full network. But the check box for that is disabled.   This is on an #RBR50 with 2 #RBS50 satellites.   I vaguely recall th...
  • RocketSquirrel's avatar
    RocketSquirrel
    Feb 21, 2023
    I remembered the hack. It is to edit the file /www/WLG_wireless_guest1.htm
    and comment out the test for enable_ap_flag. This is bogus anyway, there's
    no reason to disable this.
    if(/* enable_ap_flag == 1 || */ fbwifi_enable == '1' || enable_extender_flag == '1')
    setDisabled(true, form.allow_access);
