seansh
Aug 03, 2022Aspirant
Can't change admin password on RBR50
I'm not able to change the admin password on my RBR50. I've had a non-default password for a couple of years that works fine, but when I try to set a new password from the Administration / Set Passw...
- Aug 03, 2022
Sounds like a reset is needed.
Aug 03, 2022Guru - Experienced User
What browser are you using? Try a different browser, MS Edge or Firefox?
Try a full on reboot of the RBR, then log in with a browser that had it's cache cleared and try again.
If it still fails, factory rest and setup from scratch. Walk thru the setup wizard. Be sure to write down important information for safe keeping.
- seanshAug 03, 2022Aspirant
It's failing with Firefox, Chrome, and Brave. I'll try a full reboot and try again on Chrome after flushing the cache.
