seansh's avatar
seansh
Can't change admin password on RBR50
I'm not able to change the admin password on my RBR50.  I've had a non-default password for a couple of years that works fine, but when I try to set a new password from the Administration / Set Passw...
  • FURRYe38's avatar
    Sounds like a reset is needed.
