Rikerrock
Jul 28, 2019Tutor
Can't change icons of attached devices
Have most updated firmware. I click on attached devices and then click on say a HP printer and I change the icon to printer. Says updating, but right back to standard icon. Any suggestions?
CrimpOn
Jul 28, 2019Guru - Experienced User
Is this on the web interface "Attached Devices" page, or on the Orbi "app"? On the web interface, when I click on "Apply", the icon changes.
(on my RBR50).
Rikerrock
Jul 28, 2019Tutor
web interface. Tried many times
- CrimpOnJul 28, 2019Guru - Experienced User
Thanks for confirming. How about this: on the Attached Devices page, when you click on a device and it brings up the page with boxes for:
Device Model
Device Name
Device Type
If you change one of these, say "Device Model" and click on "Apply", does it change? (Hint: I just add one letter to the end, like an "X". Makes it easy to change it back.)
If you change "Device Name",and click on "Apply", does that change take?
So, finally, changing "Device Type" to one of the other choices, and clicking on "Apply", that is the only thing that doesn't work?
Mostly, we get complaints that Netgear does not offer enough options for Device Type (I have made a formal request on the "Ideas" page).
This is a "new one".
- RikerrockJul 28, 2019Tutor
It will change to what I type, just not the icon selection.
So, if you change the Device Type from "Printer" to "Camera" and click "Apply":
(1) The Attached Devices page will still show a Printer Icon, and
(2) If you once again click on the device and go to the page, the box for Device Type will show "Camera" (not the original "Printer")???
