Rikerrock
Jul 29, 2019Tutor
Can't change icons of attached devices
Have most updated firmware. I click on attached devices and then click on say a HP printer and I change the icon to printer. Says updating, but right back to standard icon. Any suggestions?
Rikerrock
Jul 29, 2019Tutor
It will accept when I type say hp printer; But when I try to switch Icon from "network" to "printer" it goes right back to network after hit apply. Hp printer is saved however.
ekhalil
Jul 29, 2019Master
Rikerrock wrote:It will accept when I type say hp printer; But when I try to switch Icon from "network" to "printer" it goes right back to network after hit apply. Hp printer is saved however.
- Is the printer you’re trying to change icon for attached to the Router or one of the Satellites? Do you see the same issue for devices attached to the Router as well as for those attached to a Satellite? Do you have wireless or wired backhaul?
- Have you tried changing the device type from the Orbi app instead?
- RikerrockJul 29, 2019Tutor
The orbi app lets me change it to a printer icon. But when I go out and back into the attached devices on the app, it's back to just network ico.
- CrimpOnJul 29, 2019Guru - Experienced User
So, both the web interface and the Orbi "app" have the same flaw (for you): changing the "Device Type" does not "take".
p.s. I experimented with a device that is definitely connected to the satellite (rather than the router). For me, changing the "Device Type" and clicking "Apply" works every time. Changed a camera to a printer, and back again. No problem.
This is truly strange.
- ekhalilJul 29, 2019Master
Rikerrock wrote:The orbi app lets me change it to a printer icon. But when I go out and back into the attached devices on the app, it's back to just network ico.
Have you checked if the printer is attached to the Satellite or the Router? If you have issues with the link to the Satellite and the device is attached to the Satellite then this might happen.
As a test, please switch off the Satellite and see if you can change the device type!
- tuna_ertemalpJul 31, 2019Luminary
I am having a similar problem that I reported to Support. I have 40+ devices properly modeled/named/typed manually by me, except that one network switch I added (the 7th of such switches the first 6 of which had no problem) can be renamed, but not modeled/typed. It stays at "---" and "Network". I have been in touch with support as they are trying to isolate it, and they have my RBR50V2's backup CFG. Issue didn't get raised up to the Engineering, yet. I have attached a link to this thread in my support thread, in case they are interested in getting more data from someone else.
As a side: in my case, all satellites are wired backhaul, and this switch along with all other switches are topologically wired back into the router and not into any satellites. So... Yeah... There is that. Very strange.
I am predicting this is a bug in the firmware where some local buffer in the code is getting just the right amount/kind of data or overflow that causes an error in setting the property for that device entry, and it silently fails.
Tuna
- ekhalilAug 01, 2019Master
As a further troubleshooting of this issue I suggest doing the following telnet printout which will give us some information about why Orbi is behaving the way it does:
- Check the MAC address of the device you have issue with, let's say it's xx.xx.xx.xx.xx
- Enable telnet on the Router (from the /debug.htm page of the web interface)
- telnet to router from your computer
- After loggin in, run the following print comands on the command line:
- nvram show | grep xx.xx.xx.xx.xx
- Repeater the same procedure and do the same printout in the Satellite.
- tuna_ertemalpAug 01, 2019Luminary
I'll go first... One day last week I added 3 switches to my network, and tried to rename/remodel/retype all three, just like I had done with 4 other switches, exact same models, successfully. But this time, two of them were a success, the remaining one only took the name. To this day, I cannot set the model/type on that one. Plus, since then I added more devices to my network, things like PC/XBox/BluRay etc., and I could rename/remodel/retype them all. Netgear Support is insisting on "Save config, reset, reboot, restore, try again" and I am NOT doing that because I don't trust the firmware that seems to have such silly bugs destroy my TONS of settings & customizations that built up over the last two months.
So, I did nvram show on all three recent equivalent devices. "Gameroom1" and "Gameroom2" seem to have everything. Noticeably, "North Bedroom" is missing both of the orbi_dev_name_ntgrXX and orbi_dev_type_ntgrXX entries, and has an extra orbi_hid_mac that the other two don't; what is that?*** nvram show | grep 08:36:C9:16:04:C4
access_control51=0 08:36:C9:16:04:C4 0 56335 Unknown 1 0
orbi_dev_name_ntgr49=08:36:C9:16:04:C4 34 Netgear
orbi_dev_type_ntgr49=08:36:C9:16:04:C4 1 1
orbi_dev_name57=08:36:C9:16:04:C4 Gameroom2 8x Switch GS108Tv3
reservation10=192.168.1.12 08:36:C9:16:04:C4 Gameroom2 8x Switch GS108Tv3*** nvram show | grep 08:36:C9:15:FF:9C
access_control52=0 08:36:C9:15:FF:9C 0 56340 Unknown 1 0
orbi_dev_name_ntgr50=08:36:C9:15:FF:9C 34 Netgear
orbi_dev_type_ntgr50=08:36:C9:15:FF:9C 1 1
orbi_dev_name56=08:36:C9:15:FF:9C Gameroom1 8x Switch GS108Tv3
reservation9=192.168.1.11 08:36:C9:15:FF:9C Gameroom1 8x Switch GS108Tv3*** nvram show | grep 08:36:C9:16:03:10
orbi_hid_mac=08:36:C9:16:03:10
access_control56=0 08:36:C9:16:03:10 0 56333 Unknown 1 0
orbi_dev_name58=08:36:C9:16:03:10 North Bedroom 8x Switch GS108Tv3
reservation11=192.168.1.13 08:36:C9:16:03:10 North Bedroom 8x Switch GS108Tv3So, I am now wondering if I could set them through telnet. I am not at all pro with that stuff. But, looking at all the nvram show | grep dev_name and nvram show | grep dev_type, it seems "54" is the next unused slot for model/type. Could I do the following?
nvram set orbi_dev_name_ntgr54=08:36:C9:16:03:10 34 Netgear
nvram set orbi_dev_type_ntgr54=08:36:C9:16:03:10 1 1nvram commit
Would that hurt/brick my router?
Thanks
Tuna
PS: These switches are directly connected to the router via a wired path. No satellite is involved.
- CrimpOnAug 01, 2019Guru - Experienced User
Not sure if that will help. I 'dumped' NVRAM on my RBR50 and RBS50, sorted everything alphabetically, and set up a comparison. (At least on my system) the router has two tables that are not present on the satellite:
Router Satellite
reservationxx Not present on satellite
orbi_dev_namexx Present, but not identical
orbi_dev_name_ntgrxx Not present on satellite
The satellite has nothing to do with assigning IP addresses, so it does not need the "reseravation" table, and
the satellite Connected Devices (not "Attached") does not show the icons, so it does not have that table, either.
I was surprised to learn that the orbi_dev_name table on the satellite was missing an entry that is on the router. My guess is that this device has never connected to the satellite, and thus the satellite has never had occasion to ask for its name. Actually, that is totally incorrect because the satellite has names for devices which are wired directly to the router. Thus, I have no explanation.
All my stuff is connected to the router. Nothing is wire-connected to a satellite. By hanging my satellites' wired backhaul to switches, I make sure that they are ONLY responsible for extending the wireless SSID network instead of also acting as wired network switches. So, every wired device on my network, including the satellites, and essentially wired back to the router via wired switches. So, missing variables for type+model in my case are only relevant on the router.
Tuna
tuna_ertemalp wrote:.........
This is exactly what you need to do.
If you're sure that slot 54 is empty then please go ahead and enter the commands as you stated above, but adding quotations to the commands or follow the following:
You can first print the existing values to make sure they're empty and to set them back to their original back if ou want to roll back the changes.
- config get orbi_dev_name_ntgr54
- config get orbi_dev_type_ntgr54
- config set orbi_dev_name_ntgr54="08:36:C9:16:03:10 34 Netgear"
- config set orbi_dev_type_ntgr54="08:36:C9:16:03:10 1 1"
- config commit
YES! YES! OMG! YES! THAT WORKED! YES!
:smileylol:
I am so glad I stuck my nose into this thread and got this solution. Thank you!
Only if the Netgear Support asked for this info instead of telling me to backup/reset/reboot/restore the router first...
Tuna
I don't know if this sort of approach will fix it for Rikerrock or CrimpOn, so I am not marking your response as a Solution. It certainly solved mine, but I will leave the honor of marking it as such to the person who started the thread...
I'm glad that this helped! :)
CrimpOn wrote:......
The orbi_dev_name table should be identical between Router and Satellite. It's the Router who always update the Satellite when you click Apply when setting the IP reservations or when changing the device names in the Attached Devices list.
In fact, if you factory reset the Satellite. Then the Router will -while doing "Config Sync" when you add the Satellite to the Router- will copy -among other things- this table to the Satellites completely as it is in the Router.
ekhalil wrote:As a further troubleshooting of this issue I suggest doing the following telnet printout which will give us some information about why Orbi is behaving the way it does:
Rikerrock Please follow this procedure for your printer so we can get this fixed.
- RikerrockAug 01, 2019Tutor
I'll try that when I get home
THanks
ekhalil wrote:
tuna_ertemalp wrote:- config set orbi_dev_type_ntgr54="08:36:C9:16:03:10 1 1"
- config commit
I remain "confused". When I dump NVRAM, I do not see any variables named orbi_div_type_ntgrxx
So, there are variables that respond to "get" and "set", but not to "show"?
Just to make sure (and, I might have been blind and missed the answer in the earlier parts of the thread): Have you ever gone into the router's web admin page, click on Attached Devices, and then click on at least one device on your network, and change the Device Model, Device Name and Device Type settings from the screen that would show up? If you didn't, these variables might have never been created because the router didn't need them. Since I have done this for every single device on my network, something like ~50-55 devices by now, I do see them in my "nvram show" output: 54 names and 11 types, actually. And, that is a bit strange. I did a nvram show on another switch that I properly and manually typed as switch, but its data doesn't have a orbi_dev_type_ntgrXX associated with its MAC address althought it has orbi_dev_name_ntgrXX. So, there must also be some other way each device's type is known to the router. Weird.
Oh, yes. The reason I dread a "factory reset" is that I have (a) assigned IP addresses, (b) given specific names, and (c) changed the device type spelling (and icon) on over 30 devices.
I just now did a telnet to my Orbi router and entered
config get orbi_dev_type_ntgr2
and got... nothing. tried a bunch of other numbers as well, such as 3, 4, 5, 6, 7, 8, 9, 10, 21, 31.
And, when I do nvram show there is not a single line spelled orbi_dev_type_ntgrxx. Not one.
I realize that the integer "numbers" are related to icon files. Would be interesting to see where the heck they are.
CrimpOn wrote:Oh, yes. The reason I dread a "factory reset" is that I have (a) assigned IP addresses, (b) given specific names, and (c) changed the device type spelling (and icon) on over 30 devices.
Yup. Exactly the boat I am on... :(
Do you have any orbi_dev_nameXX and orbi_dev_name_ntgrXX? If so, I wonder if at times the icon implies the type. In which case, why do I even have ANY orbi_dev_type_ntgrXX variables. Lol!
Tuna
Not sure what any of this means:
root@Matrix:/# root@Matrix:/# nvram show | grep 08:36:C9:0B:37:21 satellite1=08:36:C9:11:90:95 192.168.1.90 RBS50 5VF1935K02D98 -95 V2.3.5.30 1 08:36:C9:0B:37:21 wired 1 -95 satellite2=28:80:88:DD:24:99 192.168.1.88 RBS20 5DL88C5X0C61D -95 V2.3.5.26 1 08:36:C9:0B:37:21 wired 1 -95 orbi_dev_name2=08:36:C9:0B:37:21 Matrix satellite3=08:36:C9:11:90:31 192.168.1.43 RBS50 5VF1935L02D99 -95 V2.3.5.30 1 08:36:C9:0B:37:21 wired 1 -95 satellite4=28:80:88:E0:E8:FB 192.168.1.56 RBS20 5DL88C5N0E7B6 -95 V2.3.5.26 1 08:36:C9:0B:37:21 wired 1 -95 access_control46=0 08:36:C9:0B:37:21 0 32966 Unknown 0 0 disconn_sate1=08:36:C9:11:90:95,0,0,08:36:C9:0B:37:21,0 disconn_sate2=28:80:88:DD:24:99,0,0,08:36:C9:0B:37:21,0 disconn_sate3=08:36:C9:11:90:31,0,0,08:36:C9:0B:37:21,0 disconn_sate4=28:80:88:E0:E8:FB,0,0,08:36:C9:0B:37:21,0 root@Matrix:/# root@Matrix:/#
- RikerrockAug 02, 2019Tutor
- CrimpOnAug 02, 2019Guru - Experienced User
This is the key to my problem. How can some of you have a variable named orb_dev_typexx and I do not?
My orbi_dev_name_ntgrxx entries have the MAC address, followed by a number, followed by a description. I believe the number is an index into the table of device icons.
- ekhalilAug 02, 2019Master
I don’t have any orb_dev_typexx parameters with values.
I believe those will be set when using certain devices like managed switches.
The device icon is included in the parameter orbi_dev_name_ntgrxx.
rbi_dev_name_ntgr3=”7C:E9:D3:99:A3:03 27 HP LaserJet 400 M451dw”
The 27 in the above command means printer.
The known types are as follows:
0 Orbi Satellite
17 iPhone
27 Printer
14 iPad
28 Repeater
23 Media Device
5 Apple Airport
24 Network Device
29 Satellite STB
41 Apple TV
7 Bridge
35 TV
22 MacBook
9 Camera
13 iMac
6 Blu Ray
38 Windows PC
2 Android Device
I guess that the orb_dev_typexx parameter specifies sub types for certain devices and they will only appear if you use such devices, like managed switches. - tuna_ertemalpAug 25, 2019Luminary
Just to put an update on this thread: Since my last post here, I have added a bunch of devices to my network, and rather randomly either the Device Model (orbi_dev_name_ntgrXX; I am up to XX=66) and/or the Device Type (orbi_dev_type_ntgrXX) on the Edit Device page didn't result in the correct setting actually taking place, therefore requiring me to go through telnet to create/set the proper config variables. I had also created a support case for this exact issue the first time I had run into it (Case #41517573), but as soon as I "fixed" it manually via telnet and config variable shenanigans, it got closed.
I am not sure if the firmware dev team even has this on their radar, but they absolutely should. This is clearly a bug in the firmware code dealing with the creation of these config variables. It must be error'ing out at certain device names/types or at a certain XX value, or some local buffer is just not big enough and the config creation code is running out of space while trying to do the right thing.
Therefore, I am tagging Blanca_O. This really does need to be escalated.
Thanks
Tuna
- alkah3stAug 30, 2019Initiate
I have the same issue. Using the genie interface leads to some devices refusing to accept the device name I enter or not switching to the icon I chose. In the Android app, it readily accepts the name, but sometimes won't display the icon I selected and revert back to whatever it was before I saved.
