Rikerrock
Jul 28, 2019Tutor
Can't change icons of attached devices
Have most updated firmware. I click on attached devices and then click on say a HP printer and I change the icon to printer. Says updating, but right back to standard icon. Any suggestions?
tuna_ertemalp
Aug 01, 2019Luminary
YES! YES! OMG! YES! THAT WORKED! YES!
:smileylol:
I am so glad I stuck my nose into this thread and got this solution. Thank you!
Only if the Netgear Support asked for this info instead of telling me to backup/reset/reboot/restore the router first...
Tuna
tuna_ertemalp
I don't know if this sort of approach will fix it for Rikerrock or CrimpOn, so I am not marking your response as a Solution. It certainly solved mine, but I will leave the honor of marking it as such to the person who started the thread...
