Rikerrock
Jul 28, 2019Tutor
Can't change icons of attached devices
Have most updated firmware. I click on attached devices and then click on say a HP printer and I change the icon to printer. Says updating, but right back to standard icon. Any suggestions?
EduardH
Oct 13, 2019Guide
Same here. This is after the latest firmware upgrade. The bad thing is that support simply does not reply to my request, even when I remind them. I have not found the solution, also in the webbrowser will the system replace the icon back to the old setting. Very annoying this.
