Irkmiller
Sep 21, 2021Aspirant
Can't complete setup - Orbi RBR10
I have followed the iOS app procedure and get through to the screen where the app claims it is checking to see if the "mobile device is connected to the Orbi" and then it fails. If I open my mobile d...
- Sep 21, 2021
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou'll need to contact your ISP for help with there modem
Try using a wired PC and web browser to setup the Orbi system instead of the Orbi app.
Sep 21, 2021Guru - Experienced User
Couple of options,
- IrkmillerSep 21, 2021Aspirant
I'm actually thinking of going with option 4 and buying my own cable modem to replace my ISPs locked out piece of crap. Thanks for pointing out a few things I needed to be aware of to reach this decision. I'm paying $10 a month to lease something I'm not allowed to use to its full potential.
- FURRYe38Sep 22, 2021Guru - Experienced User
đ
