Catalyst_oz
Jan 31, 2020Aspirant
Cant conect Robomaster S1 to Orbi setup but works fine with Nighthawk R8000
I am trying to connect my new DJI Robomaster S1 to my Orbi RBR50 but it never connects, so I pulled out my old Nighthawk R8000 and set it up on the test bench, the Robomaster connects fine to one of ...
Jan 31, 2020Guru - Experienced User
Try disabling the 5G SSID broadcast on the RBR:
Be sure to forget the current wifi profile on your setup device, i.e. phone or pad. Then power OFF the wifi radio on the phone or pad, then re-enable it. Reconnect to Orbi's wifi SSID again and enter in the PW on the phone or pad. The phone or pad should now be connected to the 2.4Ghz radio only on the Orbi. Try the setup process for your device.
