AussieOrbi
Jan 13, 2020Aspirant
Can't connect Amazon Echo Dot (Gen 3) with my Orbi RBR50
Hi, I've spent hours trying to work this out and slowly going insane. I've got a Netgear Nighthawk X4S D7800 connected to an Orbi RBR50 with 2 x RBS50 satellites Orbi RBR50 and RBS50 on...
Jan 14, 2020Guru - Experienced User
Did you disable the 5Ghz SSID Broadcast Under Advanced Tab/Advanced Settings/Wireless Settings. Then Try to connect the Dot?
"I've tried on the Orbi network:
- Changing security method and trying to connect the Echo Dot
- None - Doesn't work" < IF this fails then the Dot is faulty. Try another Dot.
- What mode do you have your D7800 in? Modem only or router mode?
This is a modem with built in router. Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
