Starhalls
Mar 20, 2018Follower
Can't Connect Amazon Echo or Echo Dot To New Orbi Wifi..Help!
So we just got a new Orbi system (RBK50) and all devices connect just fine EXCEPT our Amazon Echo's and Echo Dot's. They won't connect to our wifi at all. I even tried deregistering one of the Echo's...
GlennMc
Nov 16, 2019Aspirant
Had the same issue (echo not connecting) and the security settings were the only thing that I found that would allow them to connect. Not sure what I gave up with the settings but it worked.
Tcrus
Dec 03, 2019Luminary
I am having the same problem. I just upgraded to the ORBI BK850 (WIFI 6) and for the life of me cant get alexa devices to connect to wifi. I expect a lot more from a $700 router. Anyways, I tried the method mentioneed above and no success. Anyone else find a work around?
- FURRYe38Dec 04, 2019Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Tcrus wrote:I am having the same problem. I just upgraded to the ORBI BK850 (WIFI 6) and for the life of me cant get alexa devices to connect to wifi. I expect a lot more from a $700 router. Anyways, I tried the method mentioneed above and no success. Anyone else find a work around?
- SRoth222Dec 16, 2019Aspirant
I recently purchased an Orbi RBK23 Wi-Fi mesh. I could connect my iPhones, iPad, smart LG TV, portable PC, Denon surround sound system, and even my Tesla. However, I could not get my Amazon Echo 2 or Google Home to connect! I finally got them to work by going to OrbiLogin.com and manually updating the firmware for both the modem (RBR20) and satellites (RBS20) devices. These are hot fixes (Firmware Version V2.3.5.36) and are not automatically downloaded and installed via auto update.
Now, I'm happy as a clam!
- FURRYe38Dec 17, 2019Guru - Experienced User
Glad you got it running.
FYI, the RBR is not a modem. It's a router.
Enjoy. :smileywink:
SRoth222 wrote:I recently purchased an Orbi RBK23 Wi-Fi mesh. I could connect my iPhones, iPad, smart LG TV, portable PC, Denon surround sound system, and even my Tesla. However, I could not get my Amazon Echo 2 or Google Home to connect! I finally got them to work by going to OrbiLogin.com and manually updating the firmware for both the modem (RBR20) and satellites (RBS20) devices. These are hot fixes (Firmware Version V2.3.5.36) and are not automatically downloaded and installed via auto update.
- SRoth222Jan 02, 2020Aspirant
Go to https://www.netgear.com/support/download/?_ga=2.40587618.193522718.1578010367-1975898161.1576458348
and select your device. Then download the newest version of the firmware ("Firmware Version V2.3.5.36"). Follow the instructions...
- GlobalPhenomJan 16, 2020InitiateIf you go to advanced wireless settings and uncheck the ax mode, the echos will connect properly.
