Starhalls
Mar 20, 2018Follower
Can't Connect Amazon Echo or Echo Dot To New Orbi Wifi..Help!
So we just got a new Orbi system (RBK50) and all devices connect just fine EXCEPT our Amazon Echo's and Echo Dot's. They won't connect to our wifi at all. I even tried deregistering one of the Echo's...
Dec 17, 2019Guru - Experienced User
Glad you got it running.
FYI, the RBR is not a modem. It's a router.
Enjoy. :smileywink:
SRoth222 wrote:I recently purchased an Orbi RBK23 Wi-Fi mesh. I could connect my iPhones, iPad, smart LG TV, portable PC, Denon surround sound system, and even my Tesla. However, I could not get my Amazon Echo 2 or Google Home to connect! I finally got them to work by going to OrbiLogin.com and manually updating the firmware for both the modem (RBR20) and satellites (RBS20) devices. These are hot fixes (Firmware Version V2.3.5.36) and are not automatically downloaded and installed via auto update.
Now, I'm happy as a clam!
kkzz8888
Jan 01, 2020Aspirant
Thanks SRoth222 ! I have problem connecting to my Amazon Echo Dot 3rd gen (only that, all other devices are fine). Where did you get the hotfix? My router is RBR20, with the latest official firmware version of
| V2.3.5.26 |
- SRoth222Jan 02, 2020Aspirant
Go to https://www.netgear.com/support/download/?_ga=2.40587618.193522718.1578010367-1975898161.1576458348
and select your device. Then download the newest version of the firmware ("Firmware Version V2.3.5.36"). Follow the instructions...
