Starhalls
Mar 20, 2018Follower
Can't Connect Amazon Echo or Echo Dot To New Orbi Wifi..Help!
So we just got a new Orbi system (RBK50) and all devices connect just fine EXCEPT our Amazon Echo's and Echo Dot's. They won't connect to our wifi at all. I even tried deregistering one of the Echo's...
molson1020
Jun 15, 2020Aspirant
I too recently bought the new wifi 6 router system and I am confused; didn't I just pay $700 for the AX features? Wouldn't disabling this just simply make it a non-wifi 6 router? I did try this solution and sure enough, it let me connect, but then I switched it back and it would no longer connect.
Help me understand if disabling AX does not impact performance?
Mikey94025
Jun 15, 2020Hero
molson1020 wrote:I too recently bought the new wifi 6 router system and I am confused; didn't I just pay $700 for the AX features? Wouldn't disabling this just simply make it a non-wifi 6 router? I did try this solution and sure enough, it let me connect, but then I switched it back and it would no longer connect.
Yes, it's not ideal for you to disable AX on your new AX router and will impact performance for wifi 6 devices (like iPhone 11 Pro). Instead, first try setting CTS/RTS to 2347 in Advanced...Wireless Settings at http://orbilogin.com/start.htm This fixes some wireless compatibility issues with the Orbi AX.
See the Orbi AX forums for other threads specific to the AX systems: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
