ME23
Nov 27, 2018Tutor
Can't connect my device
I have an air filter that is app controlled via my Android phone and it will NOT connect to my Orbi RBR40. I haven't had problems with any other device and I was able to connet to the air filter when...
st_shaw
Nov 27, 2018Master
You could try to temporarily disable broadcast of the 5 GHz SSID during device setup. This is under Advanced, Advanced Setup, Wireless Settings on the Orbi web interface.
