jenniferlynch
Apr 14, 2020Follower
Cant connect my nintendo switch to my ORBI RBR40
I am having trouble connectinbg my kid's nintendo switch to my Orbi RBR40. Says it needs to be registered. I am already reset the router and nintendo system-no luck. Any help would be greatly appre...
EHECATL80
Apr 29, 2020Tutor
Any luck? I started having the same issue last night.
Apr 29, 2020Guru - Experienced User
So it had been working up until last nite?
EHECATL80 wrote:Any luck? I started having the same issue last night.
- EHECATL80Apr 29, 2020Tutor
Well, I set up my Switch for the first time last night. I was able to download the NES games and Super NES games. However, later that night when I went back to play them, I got the issue that the network needs to be registered and it's asking me for user authentication (username and password). I've tried many username and password combinations and still won't connect.
And I recently purchased and set up an ORBI RBK50. I works well with my laptop, iPhone, Roku, except for the Switch.
- FURRYe38Apr 29, 2020Guru - Experienced User
What happens if you disable the 5G SSID broadcast, apply the setting and try the NES again? Under Advanced Tab/Advanced Settings/Wireless Settings
