mrpergo
Feb 07, 2021Aspirant
can't connect new wifi6 orbi RBR750
I have an RBR 40 orbi system with 2 satellites that works fine. I purchased the WIFI 6 system RBK753 that has 2 satellites and I can't get the app to set it up. I've messed around for a couple hours ...
vajim
Feb 07, 2021Master
mrpergo wrote:I have an RBR 40 orbi system with 2 satellites that works fine. I purchased the WIFI 6 system RBK753 that has 2 satellites and I can't get the app to set it up. I've messed around for a couple hours unplugging and plugging modem & router and still nothing. The Orbi 45 comes up on my iphone wifi and that's it. I finally took the new system down and plugged my old one back in and it works perfect. Any help would be appreciated
You're mixing apples with oranges
recommendation : Run the 753 alone and forget the app
- mrpergoFeb 07, 2021Aspirant
I'm not trying to run them all together I'm replacing the old RBR40 system with the RBR 750 system
