mrpergo
Feb 07, 2021Aspirant
can't connect new wifi6 orbi RBR750
I have an RBR 40 orbi system with 2 satellites that works fine. I purchased the WIFI 6 system RBK753 that has 2 satellites and I can't get the app to set it up. I've messed around for a couple hours ...
Feb 07, 2021Guru - Experienced User
Orbi AC RBS are not wirelessly compatible.
Be sure your mobile phone is connected to the Orbi AX systems wifi before trying to connect the Orbi app. Or use a wired PC or laptop connected to the Orbi AX RBR to set it up.
Good Luck.
vajim
Feb 08, 2021Master
You may find more help here
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
