HoustonRider
Nov 07, 2019Aspirant
Cant connect Orbi Sat to Orbi Router while in AP mode on AT&T Fiber
Im using my Orbi RBR40 Router in AP mode for AT&T Fiber. Every wireless device is connecting to the Router, none on the Satellites. Router Firmware Version V2.3.5.30 Satellites Firmware Version...
- Nov 07, 2019
I couldnt get the Sats to sync to the Router, so I again reset the Router/all Sats to Factory defaults, rebooted and plugged Ethernet direct to Router, while leaving it also connected to the ATT modem. The web startup detected the AT modem and said I could continue in Router mode..... so, I went on with it, reset to my previous password, relocated all of the satellites, and it all looks to be working properly.
I uninstalled all devices from the Orbi app as well, it detected them and its working as well.
I still have 17 out of 18 devices connected to the router, only one shows to be connected to one of the satellites. Not sure how to "tell it" which devices. The router is in a closet behind a fireplace, in another room, and satellites are in further points around the house. Yet almost all still point to the router.
Looks like it is solved, I appreciate the efforts this afternoon! Thanks!
Nov 07, 2019Guru - Experienced User
Have the RBS FW files on a wired PC. Connect a wired PC directly to the back of the RBS. Factory reset the RBS with a press of the reset button for 15 seconds. Wait about 4-5 minutes. You should be able to open a web browser and navigate to 192.168.1.250 and the RBS web page should be seen. adming and PW is password. Send the FW file directly to the RBS.
I recommend factory reseting the RBR and RBS and setup from scratch. You should be able to configure AP mode on the RBR. First, then add the RBS lastly. I would turn OFF the RBS while you configure the RBR for AP mode. Once done, then add the RBS.
How is the RBR connected to the isp modem/router? Directly to the back or thru a LAN switch?
HoustonRider wrote:Im using my Orbi RBR40 Router in AP mode for AT&T Fiber. Every wireless device is connecting to the Router, none on the Satellites.
Satellites Firmware Version V2.3.0.28
Im aware the satellites need to be updated, how can I update them in AP mode? I've tried using ethernet to connect, but still showing "waiting for connection" on orbilogin.com. I can download the updates, but no way to get to the satellites.
If I switch back to Router Mode, Im sure the router will see the satellites, but will I lose the ATT connection?
- HoustonRiderNov 07, 2019Aspirant
Thanks, I will try that. Im on a Macbook Pro, so I will have to get an Ethernet Adapter. :smileysad:
When I log in to the reset satellite, Im not on orbilogin, how do I upload the new FW? Is the interface the same?
The RBR is connected directly via ethernet.
- FURRYe38Nov 07, 2019Guru - Experienced User
Once in the RBS web page, there is a Firmware Update section in the UI.
found a laptop with ethernet, so ive reset the RBS and no luck accessing the landing page for the orbi, just the AT&T access/control page. To be very, very clear, Im still accessing internet via Wifi AND plugged directly into the RBS via ethernet.
Is there a step Im missing?
