wwwebster
Aug 24, 2018Aspirant
Can't connect Orbi to New Zealand Vodafone FibreX
My computer can connect to my Orbi wi-fi network and the base unit is correctly connected to the Vodafone-supplied cable modem using the ethernet cable. However it is displaying the magenta ring and...
Aug 25, 2018Guru - Experienced User
What is the Mfr and model# of your ISP modem? If it's a modem router combo:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
wwwebster
Aug 26, 2018Aspirant
My modem is a cable modem only - no router fundtion. It is badged as the ISP brand, there is no evidence of any other manufacturer. My ISP-supplied router is just that, a separate router, which I am attempting to replace with the Orbi product. Thanks for the reply.
- AC641Aug 26, 2018Luminary
This will take a little figuring out from the other side of the World (UK), however, some suggestions:
- Your modem will be doing the negotiation with the network so switch 'Does your Internet connection require a login' to 'No.' This in itself may get you up and running.
- I'm not sure what the relevance of the VLAN/Bridge Group settings are for simple Internet access but I'm not familiar with your ISP. I would initially disable this.
Let us know how you get on.
