bard61
Apr 05, 2020Aspirant
Can't connect PS4 to Orbi RBR50
Just set up Orbi RBR50, working brillliantly for everything except my son's PS4. Tried wireless and LAN cable (via satellite Orbi), with no luck. Reset the firmware on PS4, still no luck. PS4 is work...
ekhalil
Apr 05, 2020Master
One of the reasons that can cause such issue is having double NAT in your network. If your ISP modem is acting as a router and does NATing on the incoming WAN traffic then this can cause different issues since Orbi is also doing NATing. You need to check if you have double NAT.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
- bard61Apr 05, 2020Aspirant
Thanks, I'm attaching a screenshot from Terminal (Mac). Apologies, but I can't tell if that second line is a second IP address. Also, after logging this question I read elsewhere that I should change the Orbi to Access Point mode (presumably to avoid the issue you've flagged) via the web interface. I've done this, but now I'm unsure as to whether I'm connecting to the Orbi, or my original modem/router, as they have the same network name (I realise now that wasn't a good idea). The phone app tells me it can't connect. I may have to do a complete re-set. Best, Brad.
