bard61
Apr 05, 2020Aspirant
Can't connect PS4 to Orbi RBR50
Just set up Orbi RBR50, working brillliantly for everything except my son's PS4. Tried wireless and LAN cable (via satellite Orbi), with no luck. Reset the firmware on PS4, still no luck. PS4 is work...
bard61
Just picked up today... what's the current FW? BTW, switching to Access Point mode seems to have done the trick... had to reboot but now things appear to be runnning as they should. Thanks for the interest and suggestions, I'll keep monitoring this...
ekhalil
Apr 05, 2020Master
If switching Orbi to AP mode helped then that for sure means that you had a double NAT and that was the root cause of the issue.
For better performance please switch of the Wifi radio on the ISP Router
