Adamc104
Sep 05, 2018Aspirant
Can't connect to Apple Music via orbit
Hi can someone help? I have recently installed an orbi mesh system, connected to my spectrum router. I can access th einternet but not apple music or download from the app store. Any ideas how to sol...
Sep 05, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Adamc104 wrote:
Hi can someone help? I have recently installed an orbi mesh system, connected to my spectrum router. I can access th einternet but not apple music or download from the app store. Any ideas how to solve this?
Adam
