jimbojames79
Jan 28, 2018Apprentice
Cant connect to Dell wireless printer 1760nw
Hi, I have installed my orbi, updated firmware and set up what seems like millions of devices seamlessly apart from my printer. It's only 8ft away from the satelitte but it can't find it. Any sugge...
cheungbut
Jan 28, 2018Aspirant
Hi,
My case, the printer is Canon TS5070. I need to uncheck the "Enable 20/40 MHz Coexistence", to make the printer connect to my Orbi. I am not sure it can fix your problem or not, but you can have a try on it.
jimbojames79
Jan 29, 2018Apprentice
Great. That seemed to get it on the network. Problem now is that my PCs can't see it. Any ideas?
